Activity Forums VEGAS Pro Importing Hyperdeck DNxHD MXF files into Vegas 12
  • Importing Hyperdeck DNxHD MXF files into Vegas 12
    Posted by Jim Mickol on June 4, 2013 at 1:50 am
    I have searched near and far to find out how to import Avid DNxHD MXF files into Sony Vegas Pro 12. I have the Avid Codec LE pack installed, but Vegas and Quicktime do not recognize the MXF files. I do see in Vegas that I can Render to that format, so it seems to be proof that the codec pack was installed. HELP!
    p.s.: I did move the files in the Program Files(x86)/Quicktime/QTsystem folder.
    Adelson Munhoz replied 13 years, 3 months ago 3 Members · 3 Replies
  • Norman Black
    June 4, 2013 at 2:53 pm
    The Avid LE codec pack only support DNxHD in Quicktime MOV files since it is a Quicktime codec pack. Same for encoding.
  • Jim Mickol
    June 5, 2013 at 1:09 am
    Well, is there any way to convert a DNxHD MXF file to something Vegas can deal with?
  • Adelson Munhoz
    June 14, 2013 at 8:21 am
    Hi Jim,
    you can use FFMBC.
    It’s a command line utility that can rewrap your AVID MXF into Quicktime. You can download the windows version of it.
    In fact it can convert almost any format into other.
    There’s a paper I found that has instructions of how to convert any file into AVID quicktime:
    6143_encodingforavidwithffmbc120114.pdf.zip
    But your issue is simpler, because both files use the same video codec.
    I do not have a AVID MXF file for testing but the command should be aproximately this:
    ffmbc -i input.mxf -vcodec copy output.mov
    The command line above does not have options regarding audio ou video tags that can be necessary for a successful conversion, but it’s a start point.
    In my case, I use it to rewrap (not convert) Vegas XDCAM422 MXF files to Quicktime XDCAM files. I Use this command:
    ffmbc -i input.mxf -tff -vcodec copy -vtag xd5b -an -threads 8 output.mov -acodec pcm_s24le -ar 48000 -newaudio -map_audio_channel 0:1:0:0:1:0 -map_audio_channel 0:2:0:0:1:1
    where:
    -tff means “top field first”
    -vcodec copy means that the output file will use the same codec
    -vtag xd5b means that the output file shoul be marked as 1080i60
    -an means “audio none” i.e. it tells FFMBC not to copy the source audio
    -threads 8 tells FFMBC to start 8 process simultaneously (which can accelerate the whole process). My machine has 8 cores, so this is the logical choice
    -acodec pcm_s24le is the audio output codec
    -ar 48000 is the audio output sample rate
    -newaudio opens a empty audio output stream
    -map_audio_channel determines how the input audio channel should be routed to the output.
    This last option demands an explanation:
    In this case, it takes the mono audio 1 of the input (stream 0.1, channel 0 or 0:1:0) and route it to the left channel of the output (0:1:0)
    Respectively, it takes the mono audio 2 of the MXF (stream 0.2 channel 0 or 0:2:0) and route it to the right channel of the output (0:1:1)
    I hope this helps.
    Regards
    Adelson
