Activity Forums Apple Final Cut Pro Legacy Importing HD from Sony HVR-V1U to FCP
  • Importing HD from Sony HVR-V1U to FCP
    Posted by Jaime Vera on May 29, 2007 at 3:11 am
    Can someone help with the settings for a project shot on Sony HVR-V1U at 1081i? I can’t see the footage when I try to log and capture. My capture settings are set to Sony 1080i50 and I’m capturing from the camera. I have machine control however I don’t have a picture. Any suggestions?
    J
    Tom Wolsky replied 18 years, 6 months ago 4 Members · 3 Replies
  • Hooban Meyer
    May 29, 2007 at 5:07 am
    I’ve had trouble with this in the past too. If you’re having the same problem I’ve had, then it’s a setting on the camera that has to be changed. And Final Cut is kind of goofy, sometimes you have to restart both the camera and Final Cut in order to get it to recognize the camera.
    Go through the VCR menu on the V1U, toggle down to In/Out Rec (the double arrows), and be sure the settings are:
    VCR HDV/DV – HDV
    Component – 1080i/480i
    i.Link Conv – Off
    Down Convert – Squeeze (This likely doesn’t matter)
    Turn everything off and restart everything. Hopefully the computer will recognize the camera. If not, keep playing with it. Obviously it’s seeing something, sometimes Final Cut is just quirky.
    Good luck.
  • Marc Lindeman
    March 2, 2008 at 6:38 pm
    I am having the same problem, I can’t get a picture to the log and capture screen. I have a blackmagic HDMI that I can use, but I prefer the fire wire. But in the capture menu, I do not have a Sony 1080i50 listed, just the DVCPRO HD 1080i setting, but it will not recognize my Camera. Anybody????
  • Tom Wolsky
    March 2, 2008 at 8:09 pm
    You use the HDV 1080i50 setting. Make sure the device is outputting the correct format.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
