Activity Forums Apple Final Cut Pro Legacy Importing Grass Valley Turbo clips (.mxf) into Final Cut with Flip4Mac
  • Importing Grass Valley Turbo clips (.mxf) into Final Cut with Flip4Mac
    Posted by Tim Wingert on August 1, 2011 at 4:58 pm
    Hello!
    I’m trying to streamline our process of using video recorded by a Grass Valley Turbo DDR and need some help.
    The files created and exported by the Turbo are .mxf. I downloaded and installed the Flip4Mac K2/Profile Component which is supposed to allow you import such things. However, when you go into Final Cut / “Import” and select the Grass Valley option, the .mxf files are not selectable in the Import dialog box (greyed out).
    Any ideas on what I can do to get .mxf’s in to FCP?
    (I have used MpegStreamClip to do this in the past, but it seems to make files that Final Cut still has a tough time dealing with..(rending after every edit, etc..)
    Thanks!!
    Tim
    Tim Wingert replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
