Activity Forums Adobe Premiere Pro importing from photoshop album to premiere
  • importing from photoshop album to premiere
    Posted by Bryan Wekiva on June 24, 2006 at 12:23 am
    I built a creation in Photoshop Album with several pictures in a slideshow format. The only option I have for saving it is in .PDF format. I would like to import this slideshow into Premiere Pro (not 2.0), but the import feature doesn’t recognize this format. Any suggestions on how I can import this? I would GREATLY appreciate any feedback
    Vince Becquiot replied 20 years, 2 months ago 2 Members · 1 Reply
  • Vince Becquiot
    June 27, 2006 at 12:41 am
    There isn’t much you can do with PDF other than reading the file in Acrobat. You will not be able to use it in Premiere.
    You probably would be better off using a program like Picassa that allows you to export to other formats, if indeed Photoshop Album only allows PDF export.
    Vince
