Activity Forums Avid Media Composer importing from FCP to Avid
  • importing from FCP to Avid
    Posted by Rick Morris on October 8, 2008 at 10:52 pm
    I have an extensive assortment of clips that are in a final cut pro project and I now need to use them with Avid. They were shot on P2 so I have the data and media but the cards were recycled a long time ago. Is this possible and if so how… Rick Morris
    Shane Ross replied 17 years, 11 months ago 2 Members · 1 Reply
  • Shane Ross
    October 10, 2008 at 3:47 pm
    If you have the data you are fine. The media you can’t work with. When FCP imports the P2 data it converts it to quicktime…proprietary quicktime…that other machines without FCP installed cannot read. But, if you have the P2 card dump…all the folders with the files that were on the P2 cards, then you can use those. Bring those over, and then go FILE>IMPORT P2>CLIPS TO BIN.
    Shane
