Activity Forums Apple Final Cut Pro Importing from camera
  • Importing from camera
    Posted by Piotr Raczko on January 8, 2013 at 12:41 pm
    Hi, I have been redirected to post on this forum.
    I just got FCPX, I switched from FCP7. In FCP7 I could directly import from camera using Log and Transfer. It worked via USB with my camera, that is Canon XF100. In FCPX I see there is an import from camera option in the menu, but it doesn’t see my camera, only the built-in iSight.
    How can I import from the camera I have directly to FCPX? What do I need to do? Is it possible that this camera is not supported and won’t work?
    Please help, thanks!
    Piotr Raczko replied 13 years, 7 months ago 4 Members · 5 Replies
  • Paul Figgiani
    January 8, 2013 at 1:28 pm
    Your camera is listed as supported:
    https://help.apple.com/finalcutpro/cameras/en/index.html?
    What are your video settings in the camera? Can you try a different card? Reformat in the camera and capture a few test shots and try again …
    -paul.
  • Tom Wolsky
    January 8, 2013 at 1:31 pm
    What version of the software are you using? Did you download the Canon plugin?
    All the best,
    Tom
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
    “Complete Training for FCPX” from Class on Demand
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Piotr Raczko
    January 8, 2013 at 1:55 pm
    The settings in camera are 1280×720 50p. It’s a two card camera. I formatted them both in camera and tried to import a new shot and no luck still. I also downloaded and installed the Canon plugin for FCPX and now there appears an XPFM13 archive in the Import from Camera dialog, but I can’t open it. It seems inactive. The camera is on and in playback mode.
    Any idea? Thanks very much in advance.
  • Jeff Kirkland
    January 8, 2013 at 6:24 pm
    If all else fails there was a n import app called XfcpX that I think should work for you. https://pika.dk/?p=472
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Piotr Raczko
    January 10, 2013 at 10:14 am
    I installed the Canon plugin but I dont see any change. FCPX still doesn’t see the camera. I’ll try out XFCPX thanks for the tip.
