Activity › Forums › Apple Final Cut Pro Legacy › Importing footage with Alpha channels
  • Importing footage with Alpha channels
    Posted by Sascha Engel on January 28, 2011 at 1:51 pm
    I seem to fall over that problems again and again: When I import footage, which I worked on in AE – e.g. created a Mask inside footage and exported it from AE with Animation Codec including the Alpha Channel – I do not seem to be able to make FCP understand and see that part to make it transparent.
    Same thing for PS – when I worked on some titles – exporting it with transparent background – FCP makes it opaque and does not recognize its transparecy. Even when I set the layer’s composite mode to Alpha Channel.
    Thanx for advice.
    Sascha
    Sascha Engel replied 15 years, 8 months ago 2 Members · 2 Replies
  • Tom Wolsky
    January 28, 2011 at 2:44 pm
    Are the Adobe products on a Mac or PC?
    After you import go to the alpha column in the browser and set the alpha channel. You did output from AE with colors set to millions+?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Sascha Engel
    January 28, 2011 at 3:46 pm
    Yes, the AE is also in my MAC. I managed to fix it with setting the Alpha Channel in the Browser Tab.
    I still struggle though sometimes with Still coming from PhotoShop – it doesn’t wanna recognize the A-Channel there. Specially, when I create something that is supposed to work as an A-Channel Mask.
    Sascha
