Activity › Forums › Apple Final Cut Pro Legacy › Importing Files into Final Cut
  • Importing Files into Final Cut
    Posted by Laura Bright on July 16, 2008 at 6:55 am
    I have to request footage (some from a few years ago) from someone, and then edit it. The original footage would have been shot on broadcast-quality cameras, however now all I suspect they have would be archives of the footage, I’m wondering:
    What format should I request this person to send it to me in so I can successfully import it into Final Cut Pro and then edit it?
    Advice MUCH appreciated.
    Laura Bright replied 18 years, 2 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    July 16, 2008 at 1:00 pm
    Ask for the same format that you intend to edit, using the same codec. Uncompressed 10bit would be nice for SD footage… is that what it is?
    I’d ask for tape if possible, then capture it yourself using the hardware you have…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Walter Biscardi
    July 16, 2008 at 1:05 pm
    Are they capturing the footage or are you? If you are capturing the footage, then you will be digitizing, not importing. If you are capturing footage, tell them to send you the footage the same format as whatever VTRs you own.
    If they are capturing the footage, tell them to capture at whatever codec you intend to edit in.
    Final Cut successfully imports dozens of codecs for editing so the choice as to which one is the “best” wholly depends on your choice.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Laura Bright
    July 16, 2008 at 11:01 pm
    It’s basically a collection of footage that once aired on television, and has already been edited and then burned onto dvd I would imagine.
  • Laura Bright
    July 16, 2008 at 11:04 pm
    Hi – the footage is from television shows that have already been edited and aired. I would be taking bits from these shows. I imagine at the moment all these old shows would be stored on dvd or something similar, in their edited format.
    As I am new to this, I am unsure what sort of ‘deck’ I should get (if the people I’m getting the footage from happen to be able to give it to me in some sort of tape format – although then I’m still not really sure exactly what sort of tape/format I should be requesting a I don’t know too much about different types of formats, or decks for that matter)
