Activity › Forums › Apple Final Cut Pro Legacy › Importing DVD’s to FCP 6
  • Importing DVD’s to FCP 6
    Posted by Toby Dye on March 25, 2010 at 12:02 pm
    Hi
    I need to import some DVD footage into FCP 6 that I will then be cutting down and exporting to upload to Vimeo at SD resolution…I’d like some advice on the most suitable codecs to use to ensure the best quality.
    I’m using Mpeg Streamclip to rip the DVDs but could someone recommend the best codec to use and then again what codec to use when exporting for upload to vimeo (I usually use h264).
    many thanks
    Toby
    Toby Dye replied 16 years, 6 months ago 2 Members · 2 Replies
  • Todd Gillespie
    March 25, 2010 at 4:18 pm
    Editing in ProRes is going to be your best choice in editing codecs. Retains the most quality, but without huge file sizes.
    I’d stick with .h264 for you’re web delivery. (Flash would be the only other consideration, but requires other software)
    Good Luck,
    Todd at UCSB
    Television Production
  • Toby Dye
    March 26, 2010 at 3:46 pm
    Great…thanks Todd.
