Activity › Forums › Apple Final Cut Pro Legacy › Importing DVD footage into FCP?
  • Miklos Philips
    November 24, 2005 at 3:52 am
    Yes. The tool I use is DVDxDV, $25 and works great:
    https://www.dvdxdv.com/DVDxDV.overview.htm
    cheers
    Point Zero Pictures
    <https://www.pointzeropictures.com>
  • Jerry Witt
    November 24, 2005 at 8:04 am
    I bought DVDxDV too. Although it’s great, MPEGStreamClip is also very good (and FREE!)
  • Steve Newnham
    November 25, 2005 at 6:27 am
    YES! Try downloading mpegstreamclip from https://www.alfanet.it/squared5/mpegstreamclip.html .
    Its free and works great. There are sometimes issues with timecode breaks in the VOB files so that you can transfer a complete 4 gig file but are only able to play a short segment although it says the whole file is there. This is because the playback head is meeting a timecode break. In the Edit (?) menu there is a ‘fix timecode break’ command. Using this has so far solved the problem.
    Good luck.
