Activity › Forums › Apple Final Cut Pro Legacy › Importing DVD footage – interlacing?
  • Importing DVD footage – interlacing?
    Posted by Steve Ward on August 28, 2011 at 12:14 am
    Hey Guys,
    I’m attempting to import some footage of a band into a doc that I’m working on.
    The bulk of the doc was shot on XDCAM EX which has been converted to ProRes.
    Settings for my project:
    1920 x 1080 HDTV 1080i (16:9)
    23.98 fps
    XDCAM EX 1080p24 35 Mb/s VBR
    About the DVD footage from MPEG Streamclip:
    Stream: VTS_01_1.VOB
    Path: /Volumes/HLG/VIDEO_TS/VTS_01_1.VOB
    Type: VOB program stream
    Duration: 0:03:56
    Data Size: 214.35 MB
    Bit Rate: 7.60 Mbps
    Video Tracks:
    224 MPEG-2, 720 × 480, 16:9, 29.97 fps, 8.00 Mbps, lower field first
    Audio Tracks:
    128 AC3 2/0, 48 kHz, 192 kbps
    Stream Files:
    VTS_01_1.VOB (214.35 MB)
    Anyhow, I’m trying to import the footage from the DVD but it always looks like this:
    I’ve tried directly importing into FCP and also tried converting it with MPEG Streamclip first.
    Any suggestions would be appreciated. Thanks.
    Chris Tompkins replied 15 years, 1 month ago 4 Members · 3 Replies
  • Jeff Greenberg
    August 28, 2011 at 5:10 am
    Well, you’re bringing interlaced clips into a deinterlaced timeline. Have you tried deinterlacing it?
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Andrew Rendell
    August 28, 2011 at 8:29 am
    As well as deinterlacing, it’ll be better to cut with if it’s 24fps to match the rest of your material, so I’d do both the deinterlace and the frame rate change with MPEG Streamclip to see what the quality’s like (there are other ways to go about it, but your quality is already compromised by coming from a DVD).
  • Chris Tompkins
    August 28, 2011 at 4:17 pm
    When you rip the disc in MpegStreamClip – select “Deinterlace”
    And ProRes.
    Chris Tompkins
    Video Atlanta LLC
