Activity › Forums › Apple Final Cut Pro Legacy › Importing dvd footage
  • Importing dvd footage
    Posted by Renato on November 4, 2005 at 3:02 am
    Hello,
    Forgive me if this sounds stupid, but I am new to both final cut and macs, so I am totally lost on this one.
    A client just gave me some footage on mini dvd discs. The discs are made from the camera itself, and they contain mpg2 video.. I need to capture that footage for a project that is due next week, and I have no idea on how to do it…
    Most of the footage is on this format, and I just wish there was a simple way to convert them to .mov files.. its ok if it gets a little compression on the way to final cut btw..
    any help or advice is highly appreciated
    thanks
    renato
    Renato replied 20 years, 10 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    November 4, 2005 at 3:12 am
    You could transfer the dvds to dv and then import the dv footage through any dv deck/camera.
    You could use mpeg streamclip to convert them in software to quicktime.
    https://www.alfanet.it/squared5/mpegstreamclip.html
    It’s free and does a dandy job.
    good luck and happy encoding.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
  • Renato
    November 4, 2005 at 3:56 am
    wow, thanks a lot for the very fast response!
    Guess I will try the encoder first and go to dv only as last option..
    its truly appreciated..thanks!!!
  • Max Frank
    November 4, 2005 at 11:39 am
    Also check out DVDxDV.com
  • Trevor Ward
    November 4, 2005 at 1:06 pm
    Or, do what I do. Plug a DVD player into my camera. Plug the camera into the computer through firewire. In the capture settings, use NON-CONTROLLABLE NTSC device and use “capture now.”
  • Renato
    November 4, 2005 at 4:24 pm
    I didnt even know that was possible..thanks for the tip!
