Activity Forums VEGAS Pro importing dv ntsc.mov’s into sony vegas
  • importing dv ntsc.mov’s into sony vegas
    Posted by Zenthor on June 8, 2007 at 2:29 am
    so i made a 6 minute video in final cut pro. exported it as dvntsc, copied it onto a portable hard drive.
    now i want to make some changes but i dont have a mac and i have sony vegas, whenever i try to import it into sony vegas i get an error that an exception has occured and the program crashes. anyone know any solutions or work arounds?
    Zenthor replied 19 years, 2 months ago 3 Members · 4 Replies
  • Edward Troxel
    June 8, 2007 at 1:20 pm
    Sounds like it doesn’t like the FCP export. What if you just print to tape from FCP and then recapture the tape in Vegas?
    Edward Troxel
    JETDV Scripts
  • Zenthor
    June 8, 2007 at 3:36 pm
    id love to but no mac,no fcp, and no tape deck
  • Imants Ozers
    June 9, 2007 at 2:36 am
    don’t know if any of this will help but…
    I have a file from FCP which did not have the .mov extention on it so Vegas would not recognize it. I can add either .mov or .avi and either way it works in Vegas. So maybe you can try a different extention and see if that works.
    Or,if the file will play in Quicktime player. If you have/get Quicktime pro($29USD), you could export from there as .avi trying various settings/compression to see if that works.
    Good luck!
  • Zenthor
    June 9, 2007 at 2:58 am
    well i found a work around… i opened the file with quicktime pro, and converted it to .avi and then imported the avi into vegas and it works
