Activity Forums Adobe Premiere Pro Importing DNxHD to Adobe Premiere Pro CS6 false Contrast?
  • Importing DNxHD to Adobe Premiere Pro CS6 false Contrast?
    Posted by Sam Sanders on August 11, 2012 at 1:53 pm
    Hello,
    I´ve got a problem with Adobe Premiere Pro CS6 and DNxHD.
    I want to correct a DSLR HD footage in After Effects. After this render it out to DNxHD and import it into Adobe Premiere Pro CS6.
    But when I watch the file into Premiere Pro the contrast isn´t right anymore. I´ve got a extrem contrast. When I watch the same file into QuickTime or import it agian in After Effects everything is fine.
    What I´m doing wrong? Please help.
    James Barton replied 14 years ago 3 Members · 3 Replies
  • Sam Sanders
    August 11, 2012 at 3:27 pm
    Okay I´ve got it. I have to change color levels to RGB Levels in DnxHD Codec Configuration.
  • Anthony Marotti
    August 11, 2012 at 4:55 pm
    Hello,
    Where do you do that?
    AM 🙂
  • James Barton
    August 12, 2012 at 12:01 am
    Keep in mind that rendering in DNxHD will clip the whites at 100–at least it does if you render thru AME–
