Importing data for a timelapse
The challenge I’m facing is fairly straightforward, but I’m not running into anything that seems to fit in looking around — maybe I’m not using the best search criteria. . .
I have a jpeg sequence and I also have corresponding metadata from those images that I need to use to generate a custom (and accurate)time stamp based on when the images were recorded. The data can be delivered in a range of formats. I have no experience with loading external data via a script, so if someone could point me in the right direction for this type of application, that would be much appreciated.
