Activity Forums Adobe Premiere Pro Importing complicated FCPX XML’s into Premiere — Possible?
  • Importing complicated FCPX XML’s into Premiere — Possible?
    Posted by Aryn Leigh on February 16, 2017 at 1:11 am
    Hi there-
    I’m working on a large-scale project where I need to import into premiere several older sequences that were cut in FCPX. So far, I’m exporting FCPXML’s into DaVinci Resolve and then back out to a Premiere-readable XML file. (I am side-stepping XtoCC here.)
    Unfortunately. Many of the provided FCPX-edited timelines were done using a multicam feature, so the sequences come in as unreadable nested files.
    Is there a workaround to this, besides working directly in FCP?
    This is a unique situation- not a typical workflow scenario, but one we are forced to work with. Many thanks in advance!
    John Pale replied 8 years, 6 months ago 3 Members · 2 Replies
  • Nicholas Lear
    February 26, 2018 at 6:11 pm
    I also ran into this problem today, with FCP XML’s from a multicam sequence not behaving after import into Resolve.
    Haven’t found a lot about this on the web.
  • John Pale
    February 28, 2018 at 2:55 am
    X to CC claims to work with FCPX multicam clips but does collapse them to regular clips with the active angle only. That’s better than an unusable nest. Its not horrifically expensive.
