Activity › Forums › Adobe Illustrator › Importing complex shapes from Photoshop for Envelope distort
  • Importing complex shapes from Photoshop for Envelope distort
    Posted by Garrett Snook on December 9, 2016 at 8:55 pm
    Currently designing a t-shirt for as a gift where a block of text is fitted into a silhouette. I’ve divided the image into individual layers in Photoshop, but when I import the PSD into Illustrator, I’m having trouble converting the shapes back into paths. Just trying to figure out how everything should be laid out in the PSD so the paths will carry over into Illustrator.
    CC 2015.3
    2012 Macbook Pro
    Running Yosemite
    Vincent Rosati replied 9 years, 9 months ago 2 Members · 1 Reply
  • Vincent Rosati
    December 20, 2016 at 12:02 am
    You’d need paths in the PSD file. In PS, r-click on the text layer and Create Work Path. Then you should be able to import as expected.
    Or you could reset the type in Illustrator, and use the AI file as your base design file.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
