Activity Forums Canon Cameras Importing Canon XF300 footage into Final Cut Pro 7 from back up copy.
  • Importing Canon XF300 footage into Final Cut Pro 7 from back up copy.
    Posted by Paul Tully on April 28, 2013 at 12:00 am
    We can’t import/transcode XF300 footage into Final Cut Pro 7.
    Does anybody have a step by step for transcoding into Apple ProRes for editing?
    We copied the job from 3 flash cards onto our back up drive but log and transfer in FCP7 is not ‘seeing’ the files.
    Any help greatly appreciated.
    Prof edwin Luna replied 12 years, 8 months ago 3 Members · 3 Replies
  • Mark Weber
    April 30, 2013 at 3:43 am
    I have not tried importing into FCP7 (use FCPX instead with an XF105) but you might try looking at the following link which seems very helpful:
    https://blog.abelcine.com/2012/02/07/how-to-import-c300-footage-in-avid-fcp-x-and-premiere/
    There is a section for FCP7. The XF300 uses the same format files as the C300.
    Hope this helps.
    Mark
  • Paul Tully
    May 2, 2013 at 10:11 am
    Problem solved! Never change the name of your files as FCP can’t read them. I had renamed ‘CONTENTS’, changed it back and Log and Transfer worked perfectly. Lesson learnt..
    Paul
  • Prof edwin Luna
    December 13, 2013 at 2:06 pm
    Thanks for the tip
