Activity Forums Maxon Cinema 4D Importing camera data to C4d
  • Importing camera data to C4d
    Posted by Nicholas Toth on May 9, 2005 at 3:08 pm
    is anyone familiar with importing camera data into c4d?
    I’m working with a rig that can produce a .aec, but is there any way to pull this into c4d?
    Or even throw it around in Excell to make it another file? I’m working in v8 but I’ll have v9 before the week is over if that makes a difference….
    rock and roll
    Nicholas Toth replied 21 years, 3 months ago 6 Members · 7 Replies
  • 7 Replies
  • Björn Marl
    May 9, 2005 at 8:25 pm
    In R9 you will find a handy tool named ASCII Importer. You can use it to load animation data from CSV/ASCII files.
  • Nicholas Toth
    May 9, 2005 at 9:42 pm
    what if i want to import a .aec file? to c4d that is
  • Adam Trachtenberg
    May 10, 2005 at 12:24 am
    I don’t think you can import an .aec file directly.
  • Chris Smith
    May 10, 2005 at 3:21 am
    The system you are using. What are all the formats it can write to?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Doug Bassett
    May 10, 2005 at 4:57 pm
    I htink you just import the After effects Camera file into excel and then save as csv
  • Lennart Wåhlin
    May 10, 2005 at 5:36 pm
    I was checking this out a about a year ago, and correct me if I’m wrong but the animation of the Camera in AE changed from 5.5 to 6.
    Earlier it was animated using “regular” rotation parameters but then changed to “point of interest” animation. That basicaly makes it pretty akward to translate it to Cinema. I’d also be happy if anyone have a neat solution.
    Cheers
    Lennart
  • Nicholas Toth
    May 11, 2005 at 1:11 am
    i’m trying the csv…..its not working though —
