Activity Forums Adobe After Effects importing camera data rom 3ds max
  • importing camera data rom 3ds max
    Posted by Robert Paynter on October 4, 2006 at 3:14 pm
    If I i render a video out in a very small resolution with no objects .. just the camera . in 3dsmax saved as a rla or rpf and then import the camera data into a HD comp. Will I encounter problems?.. will i get the data? I’m about to have a client do this .. and I wanted to see if anyone had tips or experience with this.
    Jeff Dobrow replied 19 years, 11 months ago 2 Members · 2 Replies
  • Robert Paynter
    October 4, 2006 at 3:25 pm
    I said render because the after effects help states: to create a rla or rpf file with camera data in 3dsmax, save your rendering in rpf format with coverage, zdepth, alpha channels enabled? I’m not a 3dmax guy.. so do i have to render? or can I just export out tha rla file?
  • Jeff Dobrow
    October 5, 2006 at 11:19 am
    This will not give you paractical, usable results. You can make a camera anim from RPF data generated in MAX,…BUT you also need object position data and other info to truly be able to integrate MAX output into the 3-space of AE.
    The only software out there that handles all of this beautifully, including object placement, light animation,..etc..etc…is MAX2AE by http://www.boomerlabs.com Check it out.
