Activity › Forums › Apple Final Cut Pro Legacy › importing avi files to a project in FCP
  • importing avi files to a project in FCP
    Posted by Shsk8er10 on July 1, 2005 at 6:55 pm
    whenever i import clips that are .avi files a message pops up saying that the files are not optimized for FCP. it says to use the device manager to copy the file and make it optimized for use in FCP. Does anyone know how to do this process? i would really appreciate it, if someone would help me!! thanks!!
    Berry Helfand replied 21 years, 2 months ago 3 Members · 2 Replies
  • Matthew Brunn
    July 2, 2005 at 3:42 pm
    Which codec is it? Can you see the video from the AVI? If not I always convert AVI to MOV in Quicktime pro OS9 (there is no OSX plugin for AVI) to DV and then everything is peachy.
  • Berry Helfand
    July 14, 2005 at 9:57 pm
    I just finished working with a project that included AVI files…it’s a big problem. AVI files cannot contain timecode, and this will really be an issue if you try to use media manager in the future.
    the solution , in my opinion, cannot be just converting the footage. The resulting quicktime will still have no timecode.
    the only way to really know is to check your clips with Sebsky Tools (a freeware download).
    Sebsky will allow you to see if there is timecode, or see if it’s corrupted timecode (i.e timecodes that begin at 72 hours), and then allow you to delete old code and add fresh timecode. just make sure the new code corresponds to the original code on the tape.
    this is something i painfully discovered recently, and it took me weeks to figure out. hope this helps.
