Activity Forums VEGAS Pro Importing AVI files from AVS Video Converter
  • Importing AVI files from AVS Video Converter
    Posted by Doug Grand on June 27, 2010 at 6:10 pm
    I am converting FLV files to AVI files using AVS Video Converter software 6.4 so I can work with them in Vegas Movie Studio 10.0. Problem is, only the audio portion of the AVI file imports into Vegas while the video portion is nowhere to be found. I assume it has to do with my AVI template coming out of the AVS software. But the AVS support team was of little assistance. I’m hoping someone here has encountered this issue and knows of a simple solution. Any help would be greatly appreciated.
    Doug
    Charles Lawrence replied 16 years, 2 months ago 3 Members · 2 Replies
  • Mike Kujbida
    June 27, 2010 at 9:20 pm
    Drop the file onto GSpot or MediaInfo (google them, they’re free) and see what they say about the file.
    As I recall, that software has several options, even for an AVI file.
    You’ll need to experiment to find out which AVI option will work with Vegas.
  • Charles Lawrence
    July 29, 2010 at 8:41 pm
    Hello Doug,
    I noticed your post and since I was trying to do a similar thing, except that my source was a WTV file created by Windows Media Center on my Win 7 Ultimate 64 bit platform, I thought I’d try a source like yours with a downloaded FLV from YouTube. I had been struggling with this, as you must have too, for some time, but I have gotten these settings to work. Choose the left most “To AVI” conversion mode. I created a profile within AVS Video Converter 6, version 6.4.4.420, the latest from their site, so that I can pull it up anytime I want to convert a file to import into Vegas. I use Vegas Pro 9e, so I can’t vouch for Movie Studio 10, but I suspect it will work too. The profile will convert any supported input source file to a DV-AVI file that will work in Vegas. The settings I use are in this screen snapshot. I did not adjust any of the Video Codec Advanced Settings.
    944_avsconverterprofile.png.zip
    The resultant AVI file imports into Vegas Pro 9e with both a video and audio stream. Below is the MediaInfo analysis text of the AVI file.
    General
    Complete name : D:\Downloads\Youtube Videos\SpanishRomance.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    Format_Commercial_IfAny : DVCPRO
    File size : 342 MiB
    Duration : 1mn 34s
    Overall bit rate : 30.3 Mbps
    Video
    Format : DV
    Codec ID : dvsd
    Codec ID/Hint : Sony
    Duration : 1mn 34s
    Bit rate mode : Constant
    Bit rate : 24.4 Mbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:1:1
    Bit depth : 8 bits
    Scan type : Interlaced
    Bits/(Pixel*Frame) : 2.357
    Stream size : 325 MiB (95%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Codec ID/Hint : Microsoft
    Duration : 1mn 34s
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 17.3 MiB (5%)
    Interleave, duration : 33 ms (1.00 video frame)
    Hope this helps you and any others others.
