Activity Forums Avid Media Composer Importing Audio in Subfolders to Avid
  • Importing Audio in Subfolders to Avid
    Posted by James Smith on April 25, 2011 at 12:26 pm
    I need to link a lot of audio files with video on Avid Media Composer 5.5 for Mac.
    The audio was recorded on a Roland R-44 and is made up of two .WAV files (one for each channel recorded) and each recording is in their own subfolder.
    Because of this Avid won’t just import the entire folder system using standard “Import” and the link to AMA doesn’t work either.
    Is there a faster way of importing all these files (and if possible keeping the subfolder system) into Avid other than doing them all individually?
    Any help is much appreciated.
    Jeff Greenberg replied 15 years, 5 months ago 3 Members · 2 Replies
  • Michael Phillips
    April 25, 2011 at 2:57 pm
    If there is timecode in those files, then I would not use AMA. Timecode from BWF files interpreted through QuickTime is not accurate.
    That being said, there is no direct structure profile for audio or QuickTimes that is defined in the plug-in as do XDCAM, P@ and RED for example. For that reason, there is no subfolder support at this time.
    Michael
    Michael Phillips
  • Jeff Greenberg
    April 26, 2011 at 2:14 am
    First, read waht Michael Phillips said TWICE.
    If you’re willing to forgo that….
    [Reuben Speight] “Is there a faster way of importing all these files (and if possible keeping the subfolder system) into Avid other than doing them all individually?”
    Can’t keep the folder structure.
    Can drag and drop from your native file system (just put a Finder window or windows 7 explorer window above media composer. Drag and drop import works just fine.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
