Activity › Forums › Avid Media Composer › Importing any media files to Avid via P2 import ?
  • Importing any media files to Avid via P2 import ?
    Posted by Dumeyni Arnaud on March 26, 2010 at 5:22 pm
    Hello all
    For a lot of workflow reasons and various problems, I ended up trying to import very big quicktime DV PAL movies into MC4. But as you know the MXF transcoding would be very very long… so I tried this workflow :
    – Import the files into premiere
    – In Media Encoder export them into Film P2 ( PAL DV settings in that case )
    – Use Import P2 > CLips to Bin
    – Consolidate.
    Well, it’s a lot faster but it doesn’t import the audio…
    I tried importing with the AMA link to volume tool but I got the error “cm label not unique”.
    Anyone else tried it ? Or any idea why the old P2 import works better than the AMA ? I didn’t install any drivers from Panasonic…
    Job Ter burg replied 16 years, 6 months ago 2 Members · 1 Reply
  • Job Ter burg
    March 26, 2010 at 8:04 pm
    If you import DV Quicktimes with 601 video levels, you should get a fast import.
