Activity › Forums › Adobe Premiere Pro › Importing an avid project with dnxhd-mxf into premiere pro cs6?
  • Importing an avid project with dnxhd-mxf into premiere pro cs6?
    Posted by Stefan Baumgartner on August 7, 2014 at 3:34 pm
    Hi there,
    I have an avid project which I would like to transfer to premiere pro cs6. I exported .aaf from the Media Composer imported it into PPro and tried to connect with the Avid Media Files which are dnxhd-mxf’s. It reported a generic error. I don’t have the quicktime files or the native material. The avid project is not set up with AMA – it works with the Avid Media Files (mxf-wrapped). Is there a possibiliy that Ppro CS6 reads the dnxhd-mxf’s? Maybe in CC?
    Thanks for your help in advance!
    – Stefan
    System settings:
    Mac Book Pro
    Processor 2.7 GHz Intel Core i7
    Memory 4 GB 1333 MHz DDR3
    Graphics Intel HD Graphics 3000 384 MB
    Software Mac OS X Lion 10.7.5
    Grant Singer replied 11 years, 2 months ago 7 Members · 12 Replies
  • 12 Replies
  • Tero Ahlfors
    August 7, 2014 at 3:44 pm
    The Avid created DNxHD files work only in Avid and some other programs (Scratch, Digital Vision’s software etc).
  • Shane Ross
    August 8, 2014 at 4:58 am
    [Tero Ahlfors] “The Avid created DNxHD files work only in Avid and some other programs (Scratch, Digital Vision’s software etc).”
    Incorrect. Not only does it work, but if you grab the VIDEO MXF file, it automatically links the audio one. I did a quick little demo here:
    https://www.dropbox.com/s/82udcx4cr39rpzu/AvidMedia_PPro.mp4
    But you can’t convert Avid projects to Premiere. Sequences…yes. And I just did it, and it brought over the media, and the sequence, and linked fine. This is the export setting from Avid I used. EXPORT FOR PROTOOLS, but then modified it thus:
    Shane
    Little Frog Post
  • Pat Horridge
    August 8, 2014 at 8:20 am
    Yes you can use AAF to move a sequence and move the MXF media over.
    But not all the effects will translate so it works better with simple edits.
    I’d normally provide a guide video mixdown and then remove any unsupported effects before the AAF export. The remake in PPro
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Stefan Baumgartner
    August 11, 2014 at 4:23 pm
    Hi Shane,
    thanks for your request! I exported the aaf from Avid with the suggested settings. I still get an generic error. I also recognized that I have 4 mxf-files with “A-endings” and 1 mxf-file with “V-ending” – no “AV-ending” as in your demo video. I think this describes AUDIO and VIDEO-files or AV-multiplexed files. I also cannot watch the video in the finder-preview (space button) although I installed Avid DNxHD codecs. Maybe I have to check the correct installation somewhere…
    Please see my screen videos with the exact problem. Password for both is AVID2PPRO
    Links:
    https://vimeo.com/103146499 and
    https://vimeo.com/103147461
    Any suggestions?
    thanks in advance!
    – Stefan
  • Shane Ross
    August 11, 2014 at 4:37 pm
    This might be working for me as I have Avid Media Composer installed on my system.
    Shane
    Little Frog Post
    August 11, 2014 at 8:45 pm
    thanks again Shane – but I also have avid media composer installed as trial version…
    August 12, 2014 at 2:52 pm
    hi dave, thanks. I see. I will stay on avid for this project because a huge rough-cut sequence exists already. I don’t think it works fine to relink with the mov’s. As well I would have to transcode so much footage to mov. thanks again…
  • Shane Ross
    August 12, 2014 at 3:38 pm
    [dave brues] “You cannot import a DNxHD MXF into Adobe Premiere Pro 6(include CC).”
    Uh…yes you can. I did…and I showed how I did it in my first response to this post:
    https://forums.creativecow.net/readpost/3/956913 (Watch the video…)
    When I tested if this was possible, ALL of my DNxHD footage, as Avid MXF media files, NOT Op1A exports, worked just fine. All of them.
    Shane
    Little Frog Post
  • Felix Länge
    August 18, 2014 at 4:59 pm
    Hello Ross,
    I am having big problems with this. I wish this would work for me as I can see it in your video.
    Can I ask what Version of Premiere you had? I bought a plugin by calibrated software just to get the AVID dnxhd files in Premiere Pro. Premiere doesn’t realize that the three files (Video, Audio 1, Audio 2) belong together. And it is a huge Project so making sub clips separately would be enormous? Would be happy abut fast help. Thanks already!
    Greets Felix
  • Shane Ross
    August 18, 2014 at 6:10 pm
    [Felix Länge] “Can I ask what Version of Premiere you had?”
    PPro CS6. But I also have Avid MC 7.0.4 on this system. I wonder if that helps it reconnect everything.
    Shane
    Little Frog Post
