Activity Forums Adobe After Effects Importing a sequence of still-image files
  • Importing a sequence of still-image files
    Posted by Declan Power on November 7, 2005 at 3:34 pm
    I am importing 50 images and I want to spread the sequence of 50 sec’s, I have changed the preference import settings to state 50 secs, but each time I import the seq. lenght reverts back to 2 sec’s and i cant change the lenght, any ideas would be appreciated, deco
    Steve Roberts replied 20 years, 10 months ago 3 Members · 3 Replies
  • Steve Roberts
    November 7, 2005 at 3:57 pm
    Import the sequence, then select the sequence in the Project window, then under file>interpret footage>main, set the frame rate to 1 fps.
    … if I catch your meaning. 🙂
    Steve
  • Kurt
    November 7, 2005 at 6:17 pm
    Or you can drag the folder containing the images to the Project window (NOT the images themselves).
  • Steve Roberts
    November 7, 2005 at 6:35 pm
    Check your prefs — you might need to hold down alt as you drag.
    Steve
