Activity Forums Adobe Premiere Pro Importing a prores xml from fcp7 into premiere cs6
  • Importing a prores xml from fcp7 into premiere cs6
    Posted by David Scharf on March 12, 2013 at 6:21 pm
    I apologize if this topic has already been covered (I searched the archives and couldn’t find a solution)
    I’m finally making the switch from FCP7 to CS6. I’m trying to import an xml of a prores (1080p, 23.98, prores lt) sequence from FCP 7. It doesn’t have any effects, titles, etc in it, yet Premiere keeps giving me the file import error (“this project contained a sequence that cannot be opened. No sequence preview preset file or codec could be associated with this sequence type”).
    I made sure that I created a sequence setting/preset in premiere that matches my prores sequence from FCP. If I try exporting the xml from FCP as a DV or DVCPROHD sequence, it imports just fine in Premiere. It just won’t import the prores sequence (which is a bummer because all my FCP projects use ProRes).
    I’m on a Mac Pro running Mountain Lion (10.8.2) and Premiere Pro 6.0.2.
    Any suggestions?
    David Scharf replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
