Activity Forums Adobe Premiere Pro Importing a FinalCut-7 Project in to the latest Adobe Premier
  • Importing a FinalCut-7 Project in to the latest Adobe Premier
    Posted by Rory Keenan on October 2, 2018 at 7:23 pm
    Hi
    I have to go back and re-edit a feature length documentary film to new music.
    The film was started several years ago and exists as a FinalCut-7 project.
    The producers are buying a new MacPro and outfitting it with the Adobe Suite (Premier).
    Does anyone have advice on importing a FCP-7 project in to the latest version of Premier?
    David Roth weiss replied 7 years, 11 months ago 3 Members · 2 Replies
  • Oliver Peters
    October 2, 2018 at 8:20 pm
    You have to export an XML from FCP7 and import it into Premiere. It *may* work, but probably not flawlessly. Option 2 is to roundtrip the XML through Resolve first. But in either case, you must have an XML from the FCP7 project.
    – Oliver
    Oliver Peters – oliverpeters.com
  • David Roth weiss
    October 2, 2018 at 9:25 pm
    If you have any alternate takes or other material on any tracks that you’ve disabled, you should do a save as to create a new timeline, and then delete all that material, otherwise I can assure you that your XML will be problematic.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
