Activity Forums Apple Final Cut Pro Legacy importing 640×480 into 1920×1080??
  • importing 640×480 into 1920×1080??
    Posted by Yota Matsuo on November 15, 2010 at 3:33 am
    Hi I have a headache on my hands…
    I’m working in FCP 7
    1920×1080 HDTV 1080i 16:9 timeline.
    But I also need to import a bunch of 640×480 SD DVD footage…
    I worked on a similar project before, and the rendering time was ridiculous. So I want to do it right this time… if I upres all the SD footage correctly, there should be no rendering involved…. I’m hoping?
    So I did a test, and used Compressor to try to put it in a format where the timeline won’t ask me to render. So far, totally unsuccessful.
    I know the frame rate is correct, and I think I’ve exhausted every possible codec??
    I don’t need the upres’d footage to fill the 16:9 screen. So ideally when I pop it in the timeline it should fill the canvas vertically, with 240 pixels of blank space on both sides.
    The weirdest part happens when I convert the 640×480 footage into a 1440×1080 with square pixels. If I open it in QT, it’s correctly displayed as a 3:2 picture. When I import into FCP, it stretches out the image to fill the 16:9 canvas. When I check the item properties, it tells me it has a 1440×1080 pixel aspect ratio. Then I want to punch it because I know I exported it with square pixels.
    What’s going on? Any ideas? Thank you so much!
    Yota Matsuo replied 15 years, 10 months ago 2 Members · 2 Replies
  • Michael Sacci
    November 16, 2010 at 1:55 am
    First you don’t try every codec, you use the one that matches you HD clips. Then the sequence matches the clip also.
    1440×1080 HD is a thin raster codec, in FCP it is not a square pixel resolution.
    So what are the specs of the footage you are trying to match. Is it HDV at 1440×1080 or something else at 1920×1080?
  • Yota Matsuo
    November 16, 2010 at 6:57 pm
    Thanks for the reply. Yes, the main footage is 1920×1080 so that’s what my sequence is set to. I simply dropped one of those clips into the timeline and FCP automatically set the sequence to HDTV 1080i with H264 compression.
    The reason why I thought to upres the SD footage to 1440×1080 with square pixels is because that would make a 4×3 aspect ratio that matches the original. It should fill the canvas vertically, leaving black space on the sides. This is what I want to see.
    However when I import the upres’d 1440×1080 footage, FCP automatically stretches it out, and under “clip properties” even tells me that it has 1440×1080 pixels. I don’t understand why.
