Activity Forums Apple Final Cut Pro Imported Project From iMovie Uses 16:9, Original Material is 4:3
  • Imported Project From iMovie Uses 16:9, Original Material is 4:3
    Posted by Tyler Dewitt on February 14, 2013 at 7:45 pm
    I just got a GoPro and have been shooting footage in 1920×1440 (not realizing that was 4:3). I started a project in iMovie, then decided to try my luck with FCP X. When I exported the project from FCP, it gets displayed in a 16:9 format. I started a new project (using the footage from the same shoot), and when I export the video, it comes out 4:3.
    I’m completely new to FCP, so I just want to play around and see what the different output ratios look like (I’m kind of prejudice to the 16:9, but I get that there would be clipping involved to get 4:3 to fit into 16:9).
    My completely nooby questions are: Is there a way to control aspect ratio in FCP? I thought I had just said “Use Current Settings” when exporting the projects. Is this expected behavior to have an iMovie project exported in 16:9?
    Loren Risker replied 13 years, 6 months ago 2 Members · 1 Reply
  • Loren Risker
    February 21, 2013 at 12:17 am
    It sounds like you’re exporting correctly, but not setting up your project correctly.
    Try this:
    Go to your project browser and highlight the project.
    Open the inspector/properties (command 4). In the the lower right corner of the inspector window there should be a wrench. That will give you the video resolution options FCPX offers. Unfortunately it’s not nearly as customizable as it was in FCP7.
    OutOfFocus.TV – Original series, music videos, and entertainment for your couch.
