Activity Forums Apple Final Cut Pro Legacy Imported Motion file – puzzling flash
  • Imported Motion file – puzzling flash
    Posted by Peter Wolsey on April 29, 2007 at 8:14 pm
    Constructed a simple animated name strap in Motion and imported it into FCP. When rendered on the timeline there is a single frame flash a second or so in. Damned if I can find the reason for it.
    Project is in 8bit uncompressed PAL. Any ideas? Thanks.
    Colin Mcquillan replied 19 years, 4 months ago 3 Members · 2 Replies
  • Lee Berger
    April 29, 2007 at 8:40 pm
    I’ve had this problem myself with odd frames (and fields) that appear when imported into FCP. It had to do with an effect (in my case, shadow) applied to a layer with several tracks inside or an effect applied to a single track within a layer. I can’t remember which. I discovered that I could export to a Quicktime Movie as a work around. It’s not as elegant as importing the Motion project files.
  • Colin Mcquillan
    April 29, 2007 at 10:47 pm
    I’ve had a few puzzling experiences round-tripping/importing motion files in the timeline..
