Activity Forums Adobe Premiere Pro imported image sequences get cut off half-way through in Premiere Pro CS4
  • imported image sequences get cut off half-way through in Premiere Pro CS4
    Posted by Carla Veldman on April 12, 2013 at 3:03 pm
    Hi there! I’m trying to import an image sequence (jpeg) into Premiere Pro CS4 4.2.1 and having trouble getting the clip to play in entirety. My sequence is 24 fps and the footage I’m bringing in is a 5-second piece interpreted at 12 fps. (It was shot at 12 fps via Dragonframe software, on 1’s). Unfortunately, the clip gets cut off half-way through. If I play it at 24 fps it’s all there but much too short of course, and the wrong speed. If I play it back at 12 fps, only the first half or so of it shows up. All the files are numbered correctly, so there shouldn’t be a cut-off. I feel like this might be some obvious problem, but google-and-forum searches have yielded nary a result. Wondering if anyone else has run into this or be able to tell me what I’m doing wrong?
    Background info: I’m on a Dell Inspiron 1525, Windows Vista, 32-bit operating system, using Premiere Pro CS4 4.2.1, importing jpegs as an image sequence/numbered stills. Not running any other software, codecs, playback engines etc. to my knowledge.
    Many thanks!
    Carla Veldman replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
