Activity Forums Adobe Premiere Pro Imported files as HDV but only option is to export as DV?
  • Imported files as HDV but only option is to export as DV?
    Posted by Erin Culton on January 2, 2012 at 4:29 pm
    I created a project in Premiere CS5, I captured my footage as HDV. I set my sequence settings to HDV 1080i my aspect ratio is @ 1440 x 1080. However when I export as a quicktime, apple prores 422 it renders 720 x 480 with no option for HD. I tried telling it to match my sequence settings but the sequence is set to mpeg and I don’t want an mpeg.
    Tim Kolb replied 14 years, 8 months ago 2 Members · 3 Replies
  • Tim Kolb
    January 2, 2012 at 4:43 pm
    [Erin Culton] “I tried telling it to match my sequence settings but the sequence is set to mpeg and I don’t want an mpeg.”
    Then…don’t choose match settings.
    Choose QuickTime>ProRes, as long as:
    1. …you’re on a Mac, and:
    2. …own an Apple product that has the ProRes encoder in it like a version of FCP or even Motion.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Erin Culton
    January 2, 2012 at 4:54 pm
    The problem is that no matter what settings I give the export it won’t retain the original size of the sequence. It always takes it down to 720×480 unless I tell it to match the sequence setting at which point I loose the option to change the codec.
  • Tim Kolb
    January 2, 2012 at 5:11 pm
    You’ll need to access the video settings tab to change the video settings of course…
    But if you pick “QuickTime” and then pick ProRes…at HD resolution, you’ll be set.
    The QuickTime exporter defaults to the DV encoder…you need to pick what you want if you want something different.
    TimK,
    Kolb Productions,
