Imported AVCHD video skipping on playback in viewer/canvas
Hello.
I’ve imported AVCHD video (1080/60i) from a Panasonic HMC150P into Final Cut Pro 7 using Log & Transfer.
I used the settings recommended by the camera manufacturer…
SEQUENCE PRESET: Apple ProRes422 (LT) 1920 X 1080 60I 48kHz
CAPTURE PRESENT: DVCPRO HD 1080i60 48kHz
DEVICE CONTROL PRESET: Non-Controllable Device
The problem is.. when I play it in the viewer it skips .. freezes and goes forward to catch up.
It has also happened once a piece is edited.
Is there something I’m doing wrong?
Any help would be greatly appreciated.
Thanks so much.
Kevin
Kevin Henry Mileposts
