Activity Forums Maxon Cinema 4D Important Question : How To Make Extrude Earth Map on Sphere
  • Brian Jones
    January 15, 2012 at 6:40 pm
    you either need a vector version of the continents and then extrude and Wrap that or you need to do a Displacement with a b/w image of the continents but the edges are really hard to get smooth enough that way (impossible really unless you can stay far enough away). There are vector versions out there somewhere (I don’t know where though).
    Here is one way to do the displacement method – it’s not detailed enough for what you want since it doesn’t have country lines but…
    3538_earthdisplace.zip
  • Brian Jones
    January 15, 2012 at 6:58 pm
    with solid water like your image it would be even easier
    3539_earthdisplace2.c4d.zip
    it uses the same texture as the first upload so I didn’t include it this time. Once again you could get smoother continent edges with a vector version of the continents.
  • Shehab Saleh
    February 18, 2012 at 11:23 am
    thank you so much i did it ^___^
    http://www.shehabart.com
