Activity Forums Adobe Premiere Pro import wmv sized 704 x 528
  • import wmv sized 704 x 528
    Posted by Lawrence Robbin on April 3, 2009 at 7:25 pm
    When I import a wmv into premiere 2.0 using a DV NTSC preset, it cuts off the bottom and top of the imported file. I can not figure out how to reset the aspect ratio for premiere so that I won’t cut off the full picture.
    Suggestions?
    Thanks….
    LR
    Lawrence Robbin replied 17 years, 5 months ago 2 Members · 4 Replies
  • Eddie Lotter
    April 3, 2009 at 7:36 pm
    Use the “Scale” parameter in the Effect Controls Panel to reduce the size of the clip so that nothing is cut off.
    See also: FAQ:How do I automatically scale clips to the Project Size?
    You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
  • Lawrence Robbin
    April 3, 2009 at 7:40 pm
    thanks, eddie. I’ll try it.
    LR
  • Eddie Lotter
    April 3, 2009 at 9:00 pm
    You’re welcome. Happy editing. Happy editor
    Cheers
    Eddie
  • Lawrence Robbin
    April 3, 2009 at 11:40 pm
    I’ve discovered, too, that if I set up the project as a DV Pal project, the 704 x 528 wmv file can be fully viewed.
    LR
