Activity › Forums › Canon Cameras › Import Video with Canon XL-H1 into FCP 5 thru AJA board
Posted by Adenryan on April 3, 2006 at 5:39 pmHello-
I am trying to connect my XL-H1 to my Mac thru an AJA board. I am using the SDI video out.
I have switched the Video in setting on the AJA control panel to – SDI. But the MAC is not seeing a video signal.
ANy suggestions?thank you!
adenDon Greening replied 20 years, 5 months ago 4 Members · 3 Replies -
Daniel E
April 3, 2006 at 9:49 pmYou might have to check your menu settings on the XLH1. Disconnect the camera and check to see if the SDI is turned on and to what format. Reconnect after the settings are confirmed.
Daniel Epstein
Gold Teleproductions, Inc
New York, NY
http://www.goldtele.com -
Donald Berube
April 7, 2006 at 5:45 pmAden,
You did not indicate if you are trying to output HD -or- SD from the XL H1. Please clarify.
You also did not specify which AJA card you are using. I might assume that you have an AJA Kona 2 – but again, you did not specify.
Also, what NLE software are you using? This is just as important – are your capture prefs set up properly?
Do you have an HD monitor with SDI input? That is one way you can verify that the XL H1 is outputting the correct signal.Assuming that you want to output HD over SDI from the XL H1, you have to properly set up the XL H1 to do this. Go into the XL H1 Menu, go to the Signals Setup menu and turn on the SDI output.
Are you trying to output HD over SDI -or- SD over SDI??? Please clarify so we can help you out.
Regarding the AJA Control Panel, you have to be more specific when setting it up – you’ll have to make sure that your NLE capture prefs coincide with the settings you sepcified within the AJA Control Panel.
Please calrify exactly what you are attempting to do so that we can effectively help you to find a solution.
Looking forward,
– don
https://noisybrain.com
https://www.bosfcpug.org -
Don Greening
April 8, 2006 at 3:54 am[Donald Berube] “Also, what NLE software are you using?”
The subject title of this thread indicates that Aden’s using FCP 5.
– Don
“Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
