Activity Forums VEGAS Pro import .vf files to Sony Vegas?
  • import .vf files to Sony Vegas?
    Posted by Jim Bell on August 11, 2010 at 5:41 pm
    I am brand new to SV using Version 10 Platinum with Win 7. I had several .mov files that I tried to edit down to then make a collage with transitions in between.
    The problem I’m having is that whenever I finished with a .mov edit I saved “Project As” and now have a folder of .vf files… I thought I could just bring these back into SV and drag to the tileline but now I see that they are not media files and I can’t do that. Everytime I try to open one of the .vf files I get the non-edited .mov files imported into the Media area.
    Is there a way to change the .vf to .avi of .mov to I can finish my project or do I need to redo in a different form? If I have to redo and save in a different form where could I find instructions on how to do that.
    Thanks,Jim
    Cal North replied 15 years, 10 months ago 3 Members · 2 Replies
  • Edward Troxel
    August 13, 2010 at 1:14 pm
    VF files are your PROJECT files. Basically an edit decision list. They do not contain the actual video, just pointers to the video. If you File – Open and pick one of those files, it should open fine.
    Edward Troxel
    JETDV Scripts
  • Cal North
    November 10, 2010 at 3:24 am
    I’m having the same problem. I think what the OP is asking is that you can’t import one .vf file into your main project.
    For example, I worked on a section as a seperate file and tried to put it back into my main timeline after I was done with it and it wouldn’t work.
