Activity › Forums › Adobe After Effects › Import timer into premiere Pro
  • Import timer into premiere Pro
    Posted by Stefan Katze on January 4, 2023 at 6:32 pm
    Hello everyone,
    i created a timer in after effects. The timer starts when i press the space bar and starts to count down.
    I want to import the timer into a premiere pro file. Ive tried to just use the “import” option in premiere pro. Premiere pro then asks me to select the layers i want import. But for some reason, i cant select all of the layers. Obviously the timer isnt working if there are some layers missing. can someone please tell how to bring the timer into premiere pro?
    Walter Soyka replied 3 years, 8 months ago 2 Members · 1 Reply
  • Walter Soyka
    January 4, 2023 at 8:41 pm
    When you import an AEP into Premiere, it asks you what COMPS you want to import, not what layers. (You can also just drag and drop a comp from Ae’s project panel into Premiere’s).
    If you’re seeing something different, maybe you can post a screenshot so we can help diagnose?
