Activity Forums Maxon Cinema 4D Import .tiff sequence
  • Import .tiff sequence
    Posted by Stephen Turcotte on September 14, 2012 at 7:09 pm
    I’m having trouble importing a .tiff sequence to be used as a video screen in a model. I import the material, go to animation tab, then calculate, but nothing happens.
    I’ve done this before without an issue, but maybe I’m missing something here. Any ideas?
    Brian Jones replied 13 years, 11 months ago 3 Members · 5 Replies
  • Van Berg
    September 15, 2012 at 10:59 am
    Have you set the movie end frame? under the animation tab… it’s set to 0 by default
  • Stephen Turcotte
    September 15, 2012 at 12:33 pm
    Yes, I’ve tried that but only blank frames show up. When I use a .mov file it will calculate all of the frames, but for some reason it’s not recognizing any kind of image sequence…
  • Brian Jones
    September 16, 2012 at 5:52 pm
    unless your tiffs are non-standard somehow… from the Help
    “Only Baseline TIFF is supported. Exotic formats such as CMYK images are not supported. It is, of course, not possible to give an exhaustive list of non-supported formats, since such a list in a sense could never be definitive”
  • Stephen Turcotte
    September 16, 2012 at 11:31 pm
    I exported a .TIFF sequence from AE with RGB + Alpha settings. I’ll have to try it a few other ways.
  • Brian Jones
    September 17, 2012 at 3:56 am
    that doesn’t sound like it should be a problem but it is worth a try
