Import Thumbnails not refreshing
When I go to import footage from an SD card, the thumbnails seem to be generating from the cache of the last import because they all appear as old/incorrect footage until I hover my mouse over each clip at which point the thumbnail changes to the actual video within the clip. It makes identifying clips a bit confusing.
The problem is an easy solve as it refreshes when I close & re-open the program, but I guess I’m just curious if anyone has found a way to prevent it from happening.
