Activity › Forums › Panasonic Cameras › Import Settings for P2 in FCP 6.0.5
  • Import Settings for P2 in FCP 6.0.5
    Posted by Pieter Van den berg on June 16, 2009 at 5:18 pm
    Using Final Cut 6.0.5 and was asked by one of my senior editors if something shot on the HVX can be imported to final cut in the “log and transfer” step to be letterbox sd (im assuming that the shoot footage is either 1080 or 720). I did a test with some older 1080 30p footage and found that no matter what my final cut audio video settings are, the footage still came in at 1280×1080 30p DVCPRO HD. I then created an SD down convert time line and sat through the render which seemed to work fine. Im assuming here that the editor will have a very finite amount of time to work and would like to avoid the inevitable rendering that comes with any FCP job. Is there something im missing in the log and transfer portion or are you locked in to the flavor of hd you shot at?
    thanks so much!
    Pieter, assistant editor, nyc
    Jeremy Garchow replied 17 years, 3 months ago 4 Members · 6 Replies
