Activity Forums Apple Final Cut Pro Legacy Import QT directly into DVDSP or into Compressor first?
  • Import QT directly into DVDSP or into Compressor first?
    Posted by Mike Raff on May 20, 2009 at 9:34 pm
    I tend to make DVDs with 10 minutes or less of content. My custom is to export a self-contained QT out of FCP and import that directly into DVDSP. The volume of the uncompressed content is generally in the 2-3 GB range.
    Recently, I have read some posts that advise exporting a self-contained movie out of FCP, then importing that QT into Compressor and applying the DVD: Best Quality setting.
    Is this method I should follow, as well? Or, given that my assets are well below the 4.7 GB capacity of a DVD, is the method I’ve been using just a good?
    What are the advantages, if any, of compressing such a small amount of material?
    TIA,
    Mike Raff
    Richmond, VA
    John Pale replied 17 years, 3 months ago 3 Members · 2 Replies
  • Chris Poisson
    May 20, 2009 at 10:17 pm
    Do the latter, much better workflow.
    Have a wonderful day.
  • John Pale
    May 20, 2009 at 10:44 pm
    Compressor and DVD SP use the same compression engine…however you have greater flexibility in settings.
    In your case, I would not use the “best” preset in Compressor. This is a variable bit rate preset, which is not the best choice for short videos. It’s mainly to maximize quality on longer videos… Using a low bit rate on less complex scenes and a high bit rate on complex material. For a short video, you should make your own preset using CBR (constant bit rate) of 7. This will encode very fast and at the highest safe bit rate for DVD-R. you should encode your audio to AC3, as well, altering one of the existing presets by turning off “film Standard Compression”…select “none”….and set the dialog normalization to -31. The preset incorrectly is optimized for movie theater sound systems.
