Activity Forums Apple Final Cut Pro Legacy Import problems and RT problems
  • Import problems and RT problems
    Posted by Jimena Mora on September 27, 2011 at 9:48 am
    Hello Im working on the Final Cut Pro 7, with two MOV files previously downloaded from the youtube. To convert from FLV file to MOV file I used the EVOM software. The two videos were downloaded in 420p, but the second one, even though it is also 420p and it says on youtube that it is in HQ it has less megas than the first one. Once I import these files to the FCP, the first one is complete, but the second one is lacking the ending. The audio is there but the image is not. I try converting it again from FLV to MOV, but the MOV file is complete, only when imported to the Final Cut it looses the ending.
    I tried to solve this problem by using the ending from the first sequence but when I paste it into the second sequence I cannot playback. If I change the RT to playback settings, the pasted clip from the first sequence cannot be watched, it is full of pixels. If I use Full Quality I cannot watch the clips from the second sequence. I already checked the sequence settings and they both match. So I don’t know where the problem is.
    Sorry if it sounds little bit confusing…
    Jimena Mora replied 15 years ago 2 Members · 2 Replies
  • Rafael Amador
    September 27, 2011 at 11:00 am
    Hi Jimena,
    Downlaod MPGStreamclip and convert your clips (Unscaled) to Apple 8b Uncompressed or Prores.
    Uncheck “Interlaced scaling”.
    Audio Uncompressed.
    rafael
    http://www.nagavideo.com
  • Jimena Mora
    September 27, 2011 at 11:46 am
    Rafael thank you so much! Problem solved. Now I can keep on working.
    Thanks!!!
