Activity › Forums › Apple Final Cut Pro › Import Premiere Pro project into Final Cut Pro? (2021 edition)
  • Import Premiere Pro project into Final Cut Pro? (2021 edition)
    Posted by Alice Alicesson on May 23, 2021 at 1:42 am
    How do I import a Premiere Pro project into Final Cut Pro? I’m working with a remote editor and we have different NLE’s.
    Andreas Kiel replied 5 years, 4 months ago 3 Members · 2 Replies
  • Oliver Peters
    May 24, 2021 at 9:42 pm
    You can’t import a project. You can transfer a sequence. From Premiere Pro, export an XML of the main sequence. Then use SendToX from Intelligent Assistance to convert Premiere’s XML format into FCP’s FCPXML format. Then import the new FCPXML into a Final Cut Pro event.
    PS: Some things may or may not translate correctly. Consult the info from Intelligent Assistance for details.
    PPS: Actually you may be able to get bins over. Here’s a link to the documentation.
    assistedediting.intelligentassistance.com/7toX/help/SendToX%20-%20Help.pdf
  • Andreas Kiel
    May 25, 2021 at 12:29 pm
    You ca also try the free version of DaVinci Resolve as a converter app: PPro XML -> Resolve, Resolve -> FCP FCPXML
