import photographs, speaking of PP
Here we go… again!
I know how to work with pixel aspect ratios and I know square vs. non-square, etc. Had a media100 when it was its own company!
However, I still get trapped, and can’t find a good shortcut, to importing plain old still photos when I need to run a mess of them down on a timeline.yeah, when I so this through after effects for pushes and zooms and what-not, I can interpret them there. And if I DROP a photo into a “new” photoshop document set to DV aspect ratio, the pixels are seamlessly converted there.
However, I’m trying to find a way to run a batch command to resize them, “fit” them into a dv frame size, run a level and color check, AND fix the pixels so I don’t get a squish or smash when I import them. There doesn’t seem to be a way in photoshop to actually Open a square pixxed doc into a non-square doc without physically moving it, or placing it into the new doc. resetting the pixel aspect ratio is for viewing, not correcting.This comes up time and time again, where i just want to resize a couple hundred photos, or even PP and lay them out quickly on a timeline without “fixing” each one…
anythoughts on an action command in PS that will do this within a Batch process?
(i realize this is more a PS question, but I figure the video saavy folks are over here.)
