Activity › Forums › Apple Final Cut Pro › Import Pana P2 media from hard disk
  • Import Pana P2 media from hard disk
    Posted by Tom Brooks on June 22, 2011 at 11:39 am
    I’m having no luck importing files from P2 folders saved to hard disk using Shotput Pro. FCX fails to import. All MXF files are shown in the error message. Same with files from Panasonic Lumix GH2. MTS files rejected.
    I AM able to import the Lumix files directly from camera when connected via the USB cable. Any ideas? Thx.
    Mike Fitzsimmons replied 15 years, 3 months ago 4 Members · 5 Replies
  • Paul Jay
    June 22, 2011 at 12:22 pm
    You tried open archive?
  • Robert Lindqvist
    June 22, 2011 at 12:23 pm
    I did it under “import from camera”, use archive. Then link to folder over the acctual P2 content.
    Cheers,
    Rob
    P.S. My 720p50 got wrong aspect ratio, hade to adjust manually. No numbers to check if it was correct done… Also some clips rendered out with rainbow-artifact-checker-board faulty images… dunno if that happened after I applyed slow or CC. It happens every time I try on one clip. Before it renders it looks ok, after render POFF…
  • Tom Brooks
    June 22, 2011 at 12:30 pm
    No, but thanks, I will.
  • Tom Brooks
    June 22, 2011 at 12:36 pm
    Have to use Import from Camera, open archive. That gives me access to the clips within. Then import as needed. THANKS.
  • Mike Fitzsimmons
    June 22, 2011 at 3:35 pm
    Camera archived worked for P2. No luck with files from my z7u. Anyone else get these to work from an archive?
    – Fitz
