Activity Forums Adobe After Effects Expressions Import multi layered photoshop file into aftereffects to reveal a cascading effect of layers coming in???
  • Import multi layered photoshop file into aftereffects to reveal a cascading effect of layers coming in???
    Posted by Sam Baum on January 3, 2013 at 12:05 pm
    Hi All
    I’ve got a conundrum for you.
    I have a multi (multi) layerd photoshop file. It’s a mosaic, so lots of little tiles all on seperate layers. I want to import it into aftereffects as a composition but instead of all the layers starting on frame 1, I want them stagered so that when I reneder the project, the layers appear to populate the screen in a sort of cascading effect.
    Is there a dynamic way of doing this? OR do have to do this manually?
    Sam
    Sam Baum replied 13 years, 8 months ago 3 Members · 3 Replies
  • Robert Womack
    January 3, 2013 at 1:26 pm
    Select all the layers.
    Either right-click and select Keyframe Assistant>Sequence Layers, or go to the Animation menu>Keyframe Assistant>Sequence Layers.
    Select overlap and put in the interval you want them to overlap by.
    Or you can write a script that loops through the number of layers and sets the inPoint of layer[i] to i – something along the lines of
    for (i=0; i<=composition.numLayers; i++) {
    composition.layer[i].inPoint = i;
    Note, the syntax on this is most likely all wrong, but this is the general idea.
  • Dan Ebberts
    January 3, 2013 at 1:29 pm
    How about Animation>Keyframe Assistant>Sequence Layers?
    Dan
  • Sam Baum
    January 3, 2013 at 1:43 pm
    Oh cool. Sequence layers. Never heaard of that! I’ll give that a go. thanks team!
