Activity Forums Adobe After Effects import jpeg to match comp length
  • import jpeg to match comp length
    Posted by Tom Edwards on March 2, 2014 at 12:22 am
    im adding a jpeg to a 6:00 comp.
    jpeg is coming in at 1:00
    checked preferences/import — the still footage import by by default is set to import at comp length.
    so, i changed that setting to reflect the actual length of the comp (and unchecked “import at comp length).
    is this just the case with jpegs?
    png and psd’s coming in at comp length.
    but maybe my brain is stuck.
    thanks
    Tero Ahlfors replied 12 years, 6 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    March 2, 2014 at 12:22 pm
    Are you importing a single file or are you accidentally importing a sequence?
