Activity Forums Avid Media Composer Import issues with Final Cut media
  • Import issues with Final Cut media
    Posted by Rick Neely on October 11, 2005 at 11:27 pm
    Hey guys,
    editing two different projects for same client, one in Final Cut Pro, one in Avid Xpress Pro. Need to import media captured from final cut pro as 8-bit uncompressed into the xpress project. The problem I’m having with the media is when there is rapid movement the images looked “rippled” or ruffled. Is there a codec change i can use or import I can use to clear that problem up (interlace effect, import as dv 25 or 50, anything else)?
    Rick
    Rick Neely replied 20 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
